2000 Ford Taurus Radio
2000FORDTAURUS
Electrical problem
2000 Ford Taurus 6 cyl Front Wheel Drive Automatic
I just recently purchased a 2000 Ford Taurus and the radio don't work. I can turn it on and hear static but it won't pick up any radio station. This car is installed with a 6 disc cd changer but the piece that you insert the cds in, is missing. Could this be causing my radio not to function correctly?
Dec 17, 2009 at 12:36 PM
BMRFIXIT
  • 19,053 POSTS
Radio should work when you select AM or FM
if not remove and check antenna if connected
Dec 17, 2009 at 12:39 PM
