2000 Ford Taurus Pully is loose.
62,000 MILES • 6 CYL • FWD • AUTOMATIC
KJMLGRAY
I have a grinding and rattling sounds coming from the belt area. I started replacing the power stering pump just because it is weak and leaking. While I had the pump and belt off, I noticed the air conditioner clutch cover is loose and the pully has almost a 1/4 inch play in and out. The air is still cold. Can I get away with just replacing the clutch and pulley? Or does it sound like the compressor as well?
Dec 12, 2009 at 5:45 AM
BMRFIXIT
  • 19,053 POSTS
If the compressor not frozen and still working
and you have the abilities to replace the clutch and pulley
then do so
Dec 12, 2009 at 1:33 PM
