2000 Ford Taurus Poor heat!
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGRYAN
  • 14 POSTS
Hi all. 2000 taurus 3.0L OHV, 172000km. Heat has been hit and miss, often blows only lukewarm air. Lots online about this. The thermostat is fine, and the engine reaches operating temperature in reasonable time. The blend door seems OK too. I flushed the heater core while pinching the bypass hose, and this SEEMS to have fixed it... So what is the purpose of the HEATER CORE BYPASS HOSE? I see no water control valve to cut off the coolant flow to the core when the heat is off, so why is it there? Wouldn't we all get better heat if we eliminated the bypass hose all together???
Thanks all.
Oct 22, 2010 at 8:45 AM
BMRFIXIT
  • 19,053 POSTS
flush coolant system again
The majority of repeat heater core leaks are due to high flow rate or use of poor quality coolant. However, electrolysis should also be checked
Check for voltage in the cooling system by touching the negative contact of a voltmeter to the battery ground or a known good ground and suspend the positive lead in the coolant, making sure it is in contact with the coolant but not touching any metal part of the radiator or cooling system. Both AC and DC voltages must be checked. Vehicles normally have DC voltages; however, a faulty engine block heater or faulty diode in the alternator can produce AC voltages. It is understood that coolant is lost due to heater core failure but try to obtain a voltage reading on the old coolant in the engine block before addition to or replacement of. To keep more coolant from exiting the heater core clamp off heater core lines and measure coolant in the engine block
Oct 24, 2010 at 12:32 PM
