2000 Ford Taurus P1237
2000 FORD TAURUS
DARKDRAGON381
2000 Ford Taurus
This code appeared p1237, it states fuel pump secondary circuit malfunction. The vehicle starts, all grounds that i can find check out, there is no shuddering in the vehicle and it runs as normal. I am a little lost as to why this code appeared. Thanks for any help,
Sep 12, 2008 at 12:03 PM
BMRFIXIT
  • 19,053 POSTS
Ensure ignition switch is turned to ON position
Using a DVOM, measure volts between FPDM
harness connector FPDM PWR circuit and FT RTN circuit terminals .
if volts is less than one volt replace FPDM.
If voltage is one volts or more, repair short to ground in the FP RTN circuit
good luck
Sep 12, 2008 at 1:56 PM
DARKDRAGON381
This is a rehash on some information i have found on this problem, there has been a recall by ford on the FPDM recall # 00E10 so if there is anyone else experiencing this you might want to call ford b/c there's a good chance they may take care of it for free.
Sep 13, 2008 at 4:22 AM
