2000 Ford Taurus on/off
2000 FORD TAURUS
164,000 MILES • 6 CYL • FWD • AUTOMATIC
CARLOSARTURO
I had the air conditioner replaced last year at a dealer, it has work fine since but two weeks ago as I was driving in the highway it shut off, and heat started to come on since in the ac while on fan or auto or max ac. also I have a turning (like a plastic sound fan) noice that comes in the right side usually when coming to a stop or when hitting a bump on the road, any sugestions?
Sep 16, 2010 at 2:48 AM
BMRFIXIT
  • 19,053 POSTS
If the sound is under the dash inside the car and its like as clicking plastic or skipping a gear have to suspect and check blend door and actuator
also open hood and check AC lines ,with AC on one should be hot and the other cold and if so you have for sure a blend door issue
Sep 16, 2010 at 10:01 AM
