2000 Ford Taurus OIL LIGHT ON
70,000 MILES • 6 CYL • FWD • AUTOMATIC
KELLYFAMILYOF10
HAVE HAD SEVERAL ISSUES WITH 2000 TAURUS THIS TIME I AM REPLACING THE WATER PUMP DUE TO FLUID LOSS AND ALSO THE OIL LIGHT IS ON AND I KNOW THE OIL LEVEL IS FINE WHAT SHOULD I CHECK FOR THIS ISSSUE
THANK YOU
Apr 7, 2009 at 2:36 PM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:0b06732d0d="kellyfamilyof10"]Engine Performance problem
2000 Ford Taurus 6 cyl Front Wheel Drive Automatic 70000 miles
THANK YOU[/quote:0b06732d0d]
Have Oil Pressure checked if pressure is good the most likely it's a malfunctioning Oil Pressure Switch.
Apr 7, 2009 at 2:51 PM
