2000 Ford Taurus OIL LIGHT ON
KELLYFAMILYOF10
  • 2000 FORD TAURUS
  • 6 CYL
  • FWD
  • 70,000 MILES
HAVE HAD SEVERAL ISSUES WITH 2000 TAURUS THIS TIME I AM REPLACING THE WATER PUMP DUE TO FLUID LOSS AND ALSO THE OIL LIGHT IS ON AND I KNOW THE OIL LEVEL IS FINE WHAT SHOULD I CHECK FOR THIS ISSSUE
THANK YOU
Tuesday, April 7th, 2009 AT 9:36 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Have Oil Pressure checked if pressure is good the most likely it's a malfunctioning Oil Pressure Switch.
Tuesday, April 7th, 2009 AT 9:51 PM
