there is no heat. replaced heater core. Worked for a few months. no water in the oil.
Oct 20, 2009 at 7:37 AM
BMRFIXIT
✓Experienced Mechanic
Check coolant level
Is the car reaching operating temp
Check heater core hoses if both are hot ,
if both hoses hot and not enough heat inside suspect blend door actuator
if not one hose hot and the other warm or cold the heater core need to be flushed
