THE CAR IS MAKING A NOISE AND THE RPMS DONT RUN OVER 2600 AND THE CAR ONLY GO AT 40KM
Saturday, July 24th, 2010 AT 9:16 PM
MECHANIC
Has the check engine light come on?
SPONSORED LINKS
Saturday, July 24th, 2010 AT 11:45 PM
JULIOCESAR
MEMBER
NO THE LIGHT IF OFF
Sunday, July 25th, 2010 AT 3:56 PM
MECHANIC
Can you describe the noise and aprox where it is coming from?
Monday, July 26th, 2010 AT 1:17 AM
JULIOCESAR
MEMBER
THE NOISE IS LIKE WHEN YOUR BELT IS, TODAY I CHECK THE INTAKE, AL THE AIR HOSES AND THE PCM GROUND AND AFTHER THAT THE RPM WENT UP AT 4000 BUT STIL DONT GO OVER 40K AND ALSO I RAN THE CAR IN THE AIR AND LOOKS LIKE THE TRANSMITION IS SHIFTING GOOD
Monday, July 26th, 2010 AT 8:13 PM
MECHANIC
If the check engine light isn't on, it could be weak fuel pressure, a bad vacuum leak, a plugged catalytic converter.
