2000 Ford Taurus leaking coolent
89,000 MILES • 6 CYL • FWD • AUTOMATIC
SKEETER7X
my car is leaking coolent it looks like it is coming from were the water drips from having your a/c on.
i think i ruled out water pump and all the hoses i cant get behind the heat sheild thats over the exhust to see. could it be a frost plug if so how do you tip the motor up or do you have to pull it out. maybe there is a hose i cant see.thanks, jason laBarre
Sep 7, 2009 at 10:56 AM
BMRFIXIT
  • 19,053 POSTS
Common for the heater lines to rust and leak out by the firewall
if coming from the drain tube than suspect heater core
Sep 7, 2009 at 11:40 PM
