2000 Ford Taurus inner tie rod end
JAUSTIN
Steering problem
2000 Ford Taurus V6 Two Wheel Drive Automatic 100,00 miles
how do you replace inner tie rod
my manual only talks about the outer
Dec 10, 2007 at 8:28 AM
MERLIN2021
  • 17,250 POSTS
You need to remove the outer then the dust boot, then using the special tool, remove the inner, install the new inner then the new lock pin then boot, then losk nut, then outer...then align!
Dec 10, 2007 at 9:16 AM
