2000 Ford Taurus How do I test the Crank angle sensor or th
109,000 MILES • 6 CYL • FWD • AUTOMATIC
JHA911
I have a 2000 Ford Taurus 3.0 V6 flex fuel, it was starting rough for several weeks, ( hardly at all in cold weather), I have talked to several mechanics, and I keep hearing about the crank or cam angle sensor needs to be replaced, or the timing chain might be shot. Anyone know how I can test either one of these to narrow my problem down?
Apr 3, 2008 at 9:50 AM
BMRFIXIT
  • 19,053 POSTS
Use an ohm meter
also need i would
check for a tune up and ignition wires
check for vacuum leaks
check timing
Apr 3, 2008 at 11:24 AM
