2000 Ford Taurus Heating problem
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUEMOON
I just have the car serviced 2 months ago, complete tune-up. During the process i ordered my AC/heater to be serviced too. The AC is working properly, air is cool enough. However the heater is blowing air but it's not heating up.What shoud i do?
Thanks
Aug 11, 2008 at 11:40 PM
2CARPRO JACK
  • 11,533 POSTS
Be sure it is full of coolant. Does the engine run at the normal temp range? Check both heater hoses to see if they are hot, if only 1 is hot, you may have a plugged heater core if both are hot, this could be a problem with the blend door under the dash
Aug 12, 2008 at 12:39 AM
