This has been a problem for a while. The Heat and AC work but the fan just does not blow very strong. There is clearly a difference between the four fan settings (so the motor and the controls are working) but the only way to get the cabin to heat or cool is when the fan is at the maximum setting. I have changed the cabin air filter. There isn't anything that would seem to indicate any kind of engine problem (I had read something about a possible vacuum leak).
Aug 16, 2010 at 8:58 AM
