2000 Ford Taurus having problems coming to a stop.
16,700 MILES • V8 • FWD • AUTOMATIC
CLOUD2009
when i come to a stop the anti lock system tries to go in effect other then just having a normal stop , when i slow down i can stop pretty normal . but my brke pedal almost goes to the floor board. i have changed the master selinoid and brake pads , and bleed the brake lines. clould you try to give me some advised on this matter thankyou.
Dec 3, 2009 at 10:21 AM
BMRFIXIT
  • 19,053 POSTS
Do you have the brake light on and if so check for brake fluid leaks
check for air in the system
if not check CV axles and the ABS ring on it
Dec 3, 2009 at 11:40 AM
