2000 Ford Taurus FUEL PUMP
86,000 MILES • 6 CYL • FWD • AUTOMATIC
TOKECHEEBS
I was driving down the road, and my taurus started to bog out, i let off the gas and it would stay running but as soon as i gave it gas it would bog out and finally just stopped running. i thought i might have run out of gas but i put more in and it still wouldnt start. This is a Flex fuel vehicle. I heard the pump click but it didn't sound like it was turning on completely. Any ideas?? if it is a bad fuel pump, can i use a non flex fuel pump as a substitute to try and save some money?
Apr 27, 2008 at 4:09 AM
TAURUSWHEEL
  • 718 POSTS
Pressure test confirm pump is no good??? That's one of the problems with flex-fuel vehicles, the cost of parts.. obviously you've noticed how expensive the fuel pump is, 850 aftermarket to 2k dollars for a Motorcraft pump, totally uncalled for.. any savings, real or imagined, more then offset by cost of parts and pieces.
Apr 28, 2008 at 1:48 PM
