fuel gauge not working
2000 FORD TAURUS
78,000 MILES • 6 CYL • FWD • AUTOMATIC
DP SCHROER
the fuel gauge has stopped working .i cant seem to find the problem .any help would be appreciated .
Jan 16, 2008 at 4:55 AM
LSUFAN910
This happened to me. The FFV Module is cheap and is easy to fix. I just fixed mine yesterday..................................................................................................... Please let us know if you need anything else to get the problem fixed.
May 5, 2021 at 5:07 AM
SQM
  • 6,383 POSTS
This likely due to a faulty fuel level sending unit.
The fuel level sending unit is a part of the fuel pump assembly. It consists of a float and a resistor panel. As the fuel level moves the float goes up or down and connects to different part of the resistor panel. This gets translated into the gauge readout.
In order to change the fuel level sending unit, the fuel pump needs to be removed. This will require of removal of the fuel tank.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Oct 26, 2021 at 4:39 AM
