2000 Ford Taurus FRont end rattle
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
TJROONEY
FRont end rattle near wheels at low speeds and noticeable over uneven pavement. Sway bars in tack, but plastic housing at ends cracked. boot on drivers side leaking grease. suggestions?? thanks
Oct 25, 2009 at 2:59 AM
BMRFIXIT
  • 19,053 POSTS
Most common would be stabilizer links and rod bushings
if its the CV axles boots that is leaking grease have to change or replace soon
Oct 25, 2009 at 11:46 AM
