2000 Ford Taurus Engine Losing Coolant
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARCHANGEL
I have a 2000 Ford Tempo 3.0Ltr V6 with approx 123000 miles.
It is losing coolant, and after driving approx 30-35 miles at 60+ i smell burning coolant and see steam coming from under the hood on the passenger side.
Engine is not indicating overheating, no alterations in engine handling or such. No liquid in the exhaust or discoloured/sweet smelling smoke either.
Pressure tested the cooling system, no loss of pressure over 10 mins nor visible leaks so far.
Mar 17, 2009 at 11:13 AM
BMRFIXIT
  • 19,053 POSTS
Check water pump
with engine OFF run your finger under the water pump pulley checking if wet
check if leaking by the firewall
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Mar 17, 2009 at 11:19 AM
