my engine light is flashing indicating a engine misfire. i replaced plugs, wires, and coil packs in may of 07 as i had a cylinder 1 misfire code on a cheap scanner back then. after replacing those parts back in 07 it still had the code and rough running condition, i borrowed a older snap on red brick scanner and found out through the troubleshooter it was a cam sensor. so i replaced the cam sensor again today on a hunch that was the problem again, but it is not. any ideas?
Dec 13, 2008 at 3:56 AM
