2000 Ford Taurus EGR valve
132,000 MILES • 6 CYL • FWD • AUTOMATIC
DSHS8487
I have a 2000 Ford Taurus. The check engine light is on because of a bad egr valve. I have tried to get the one off but i cannot get the nut that connects the egr valve to the tube. I have used everything from channel locks to pipe wrench and it will not move. Is there anything else i could use or do to get this thing off?
Feb 16, 2009 at 6:02 PM
BMRFIXIT
  • 19,053 POSTS
Spray it with ED40 and let it sit
or use heat
Most common to be bad is the DPFE sensor and not the EGR .
what do you have for codes ?
Feb 16, 2009 at 9:57 PM
