2000 Ford Taurus Driver's Side window
141,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKER1287
Experiencing intermittent failure of the driver's side window to go up/down. No logic when it works or does not. When it does not work there is a clicking sound as if from a relay switch located near in the interior fuse box. No other windows affected.
Should I look to replace the motor for the window or the window switch (controls all 4 windows)?
Jul 19, 2010 at 2:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if relay is clicking than it means the switch is working fine. there could be intermittent failure of the wiring or the motor either one.
Jul 19, 2010 at 2:30 PM
