2000 Ford Taurus Dashboard Lights
GERMZ26
Interior problem
2000 Ford Taurus 6 cyl All Wheel Drive Automatic N/A miles
when i'm driving my dashboard lights are dim to the point that they look like they're going out. how do you fix it and how much will it be to replace?
thank you
Oct 28, 2008 at 3:32 AM
DLOBI
  • 125 POSTS
This may sound silly but have you tried the dimming switch for the dash lights? There is a controll near where you turn the headlights on that you can turn to make the dash lights dimmer or brighter.
Aug 6, 2019 at 10:12 AM
GERMZ26
I have done that already. everythings fine with that it's just that i think my lights in the dashboard are going out how do you fix it?
[quote:ceec2b14fc="Germz26"]Interior problem
thank you[/quote:ceec2b14fc]
DLOBI
  • 125 POSTS
The bulbs behind the instrument panel should either work or not work. They shouldn't get dim. It is possible that a bad ground somewhere is affecting the bulbs but not likely. To replace them would involve removing the instrument cluster with all the gauges to get at the bulbs behind it. I don't know what that would cost however.
DLOBI
  • 125 POSTS
it is also possible that the dash lights dimming switch is bad and could be replaced.
