2000 Ford Taurus CRANKPOSITION SENSOR
120,000 MILES • 6 CYL • FWD • AUTOMATIC
WHIT2459
I SENT A QUESTION A COUPLE OF WEEKS AGO AND I DID WHAT WAS SUGESTED IT WORK FINE THEN THE OTHER NIGHT IT DID THE SAME THING AGAIN I REDID THE PROCEEDURE WITH NO LUCK SO I REPLACED THE CRANK POSITION SENSOR AND IT STILL DOSE THE SAME THING,THE ENGINE TURNS OVER AND THE TACH MOVES WITH THE ENGINE REVOLUTION BUT IT WILL NOT START,WHAT SHOULD I DO NOW,THANKS FOR YOUR HELP.
Dec 2, 2009 at 7:36 AM
BMRFIXIT
  • 19,053 POSTS
You may be dealing with a different issue
lets try and do some test to determine what is the cause of no start
if not sure how to do any of the tests you can check our video collection as it has a lot of info and it show you how to do it
1st need to check for spark
2nd turn key on do you hear the fuel pump coming on
check for fuel and fuel pressure
always check fuses before replacing any parts
let me know what is missing
Dec 2, 2009 at 11:19 AM
WHIT2459
i have already checked for spark and there was nice spark fuses and relays seem to be in order,i checked the inertia switch and it was fine i checked fuel pressure at thr fuel rail and got nothing i removed the gas cap and listened and could not hear the fuel pump, but i was wondering if a plugged fuel filter could stop the pump , i wold like to know before i remove the fuel tank to inspect the pump,
Thanks Again
Mike Whitham.
Dec 3, 2009 at 1:20 AM
BMRFIXIT
  • 19,053 POSTS
Fuel filter will not cause the pump not to work
if have no fuel pressure and all fuses and relays
ok check for power and ground at the fuel pump and suspect bad fuel pump and need to be removed and replaced
good luck
Dec 3, 2009 at 5:02 AM
