2000 Ford Taurus Coolant Leak
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEGALLOSEZ
I have a 2000 Ford Taurus V6 that is leaking coolant into the oil. I originally thought it was the head gasket but the coolant leaks so quickly into the oil I feel as if there may be something else wrong. Somebody at AutoBarn mentioned a possible issue that can be resolved from the top of the engine instead of pulling apart the motor to look at the head gasket. Any suggestions?
Dec 21, 2009 at 4:30 AM
BMRFIXIT
  • 19,053 POSTS
Oil mixing with the coolant have to suspect and check headgasket and heads
Dec 21, 2009 at 8:54 AM
