2000 Ford Taurus Cold weather problems
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAKOTABLACKY
I have a 2000 Taurus 24v DOHC with 93000 miles. In warm weather everything works great, but in weather 55 or below it is a different story. When I start the car I have to give it gas every few seconds or it will die. As soon as it tries to idle you can see the lights start to dim as the power is starting to go. When I'm driving it's fine, but when I stop at a light it wants to die again while in idle and I have to throw it in park or neutral to give it gas. Any help would be greatly appreciated.
Oct 9, 2009 at 12:56 PM
BMRFIXIT
  • 19,053 POSTS
Suspect idle air control valve
remove and clean 1st
or remove and replace
also check for vacuum leaks at PCV valve
Oct 9, 2009 at 2:31 PM
