2000 Ford Taurus codes and parts numbers
2000 FORD TAURUS
145,000 MILES • 6 CYL • FWD • AUTOMATIC
NECHAKO
Are engine codes and parts numbers different in Canada than in the U.S.. My car was made in Chicago and I live in Canada. There's a different numbered oil filter goes on than what's in the book at the lube place. My car died on the highway on a hot day last summer so I had the fuel pump and filter changed , and the numbers were different. The engine light had come on. They scanned the engine and it showed a problem with the secondary circuit in the fuel pump. So, I drive away and the engine light comes. I go back , shut it off, they scan the engine, they say it's reading same problem, reset it, i drive away and right away the engine light comes on. And it reads the same problem. The cars performance is what it should be.
Apr 1, 2008 at 9:24 AM
2CARPRO JACK
  • 11,533 POSTS
There are differnet pumps for different engines, that is why you should use the 8th digit of the vin # when getting parts for your car. You may have a flex-fuel pump in a car that didnt come with that option or something to that effect. What was the exact code that was in the PCM?
Apr 1, 2008 at 10:42 AM
