1994 Ford Taurus Oil pressure relief valve
75,000 MILES • 6 CYL • FWD • AUTOMATIC
RENAE07
I started my car and within 20 seconds the gasket was blown off the oil filter resulting in excessive oil spilling out. I have searched and talked to several people and found out that the problem was the oil pressure relief valve. My problem is that I can't find out where its located at and how to get to it to fix the problem could you please help...
Jan 15, 2008 at 10:49 AM
TAURUSWHEEL
  • 718 POSTS
The oil relief valve is within the oil pump, not serviceable.. if bad oil pump must be replaced.. I woul;d suggest hooking up a mechanical oil pressure gauge, remove the electric oil sender unit(use that fitting hole) and see what readings you get, depending on the quality of the gauge the readings may vary a bit.. hot oil pressure usually somewhere in the 40-60 psi range.. or bolt up another oil filter see what happens.
Jan 15, 2008 at 12:54 PM
