2000 Ford Taurus Car wont Start
84,500 MILES • 6 CYL • 2WD • AUTOMATIC
DOMIE D
About a month a go my Taurus with 3.0 Duratec had trouble starting. The engine would turn over but not fire up. The weather was close to 3 degrees and the car had a half a tank of gas. I put a bottle of dry gas in and waited a few days til the weather warmed up a bit and it fired up. It ran great for another month. Now 2 days ago during wet cold weather it would't start again. Over a few days I tried it again and it finally fired up with a quick key turn. I drove it for about an hour and filled the tank up and put another bottlle of dry gas in, hoping if it was condensation in the tank it would be displaced. Now it wont start again. No check engine lights on but I put a obdII scanner to it just to see if anything would show up anyway.
The engine just cold cranks like no fuel at all, so I'm thinking fuel pump. Ive read other posts here and read to check the IAC valve for movement, Check the injectors with a Niod light, and to listen for the fuel pump to click with the key turned. Just like some confirmation or more suggestions. Havent been out to do any yet because the weather is wet outside now. Thanks
Jan 20, 2010 at 10:01 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect fuel pump too
should start with all listed tests 1st
Jan 20, 2010 at 10:09 PM
