2000 Ford Taurus car will not start
DRG
Engine Mechanical problem
2000 Ford Taurus 6 cyl Two Wheel Drive Automatic
my car will turn over but will not start i have changed the fuel filter fuei pump works fine tune up just done it seems like a fuel problem, if you shoot some eather in the filter it will start for a second.
Jan 25, 2009 at 12:25 AM
BILLYMAC
  • 2,204 POSTS
hi you say pump is working have you tested the fuel pressure. check the injectors with a noid light are the injectors working> check all fuses ..is the alarm system working properly? if the noid light will not light up .the computer has shut the injectors down possibly a security prob maybe a pcm prob or even a tfi module prob. good luck billymac
Jan 25, 2009 at 2:51 AM
