The check engine came on so I had someone read the codes. I do not remember the exact codes but there were three. Bank1, Bank2 and EGR Flow errors. I was told the Bank1 and Bank2 errors indicated a clogged catalytic converter. The car would idle rough and it got worse up to the point it would die. I took a look under the hood and discovered that the ninety degree piece of hose coming off the PVC valve was almost in two pieces. I replaced the hose and the valve and the problem seemed to go away. A few days later it died again while idling. Now it will idle fine until you turn the AC on, then it dies. The car is not running any hotter than usual. Can a clogged catalytic converter be diagnosed (by a non-mechanic)? I was told the car had two catalytic converters and I should replace both of them since I would not know which one it was. Is that true? Could the issues I described be caused by something else?
SPONSORED LINKS
Thursday, May 20th, 2010 AT 8:40 PM
BMRFIXIT
MECHANIC
very common issue
remove IAC valve and clean
or replace
Thursday, May 20th, 2010 AT 10:17 PM
MCAUTHEN1972
MEMBER
I went to the local parts store and asked for an IAC (Idle Air Control Valve) and replaced it. Car is still acting the same. The car is idling around 600rpm. It will idle with the air on if the car is in neurtral. When you put it in drive, it dies. It will idle fine in neurtral and in drive without the A/C on (at around 600rpm). Looking at the diagram you sent, it appears that maybe I replaced the wrong part because it did not look like anything in the diagram. I have inserted a picture of what I replaced.
Is there something else I can try?
SPONSORED LINKS
Friday, May 21st, 2010 AT 7:56 PM
BMRFIXIT
MECHANIC
From the sound of it you have a vacuum leak
and need to have it checked
smoke test is your best bet
