why does my car cut off wheni use my ac and certain settings of my heat?
Mar 21, 2009 at 7:44 AM
BMRFIXIT
✓Experienced Mechanic
check and suspect IAC valve
check for vacuum leaks
Aug 29, 2019 at 1:02 PM
LOWCOST67
MEMBER
you need to check the a/c pump it could be locking up. it is turned on 2 ways 1st is the a/c 2nd is the defrost turns the a/c on so it wont blow pure hot air and crack the windshield when its cold
