2000 Ford Taurus cant get heater to work
2000 FORD TAURUS
140,000 MILES • 6 CYL • FWD • AUTOMATIC
CODEMAN834
Hi, I cant get the heat to work in this car. I replaced the thermostat, flushed and cleaned the system. The a/c works fine. The knob for the heat/cold spins all the way around tho, I know thats broken. But what about the heater control valve, where is that located and the control for how hot/cold you want it, could that be the problem?
Jan 16, 2010 at 1:14 PM
BMRFIXIT
  • 19,053 POSTS
For you to find the troubled area
have to start and warm engine
open hood and check heater hoses by the firewall
both hot its a blend door and or actuator issue
if one hot one warm or cold
heater core have to be flushed
Jan 16, 2010 at 1:30 PM
