2000 Ford Taurus brown coolant
110,000 MILES • 6 CYL • FWD • AUTOMATIC
TAURUSUSER
  • 5 POSTS
I got brown coolant in the tank recently. Today I detached the tank and found there are some rust-like stuff in the bottom of the tank (some but not much). Then I installed the tank back and fill new coolant. But after I turned on the engine, the brown stuff just came back from the two above small pipes (or maybe just one of them. ) The heating system still works fine. I do hear some low noise (not sure how to describe, like rattling) when engine runs nearly below 2 rpm. Others look fine.
Mar 21, 2010 at 9:10 AM
LEGITIMATE007
  • 5,121 POSTS
when you say tank do you mean radiator? also, the noise you hear maybe a little air pocket moving around in there. do a flush and see what happens. the rust is probably from other owners putting water in the system or condensation buildup, it happens to a lot of vehicles
Mar 21, 2010 at 9:30 AM
TAURUSUSER
  • 5 POSTS
The tank is the coolant overflow reservior. Should I do a coolant flush? The noise can be heard in the car on the right of the driver. Thanks
Mar 22, 2010 at 4:03 AM
LEGITIMATE007
  • 5,121 POSTS
yes I would see if you can clear the rust or discoloration out, otherwise , your gonna have to start replacing parts to get rid of the problem so lets start with a coolant flush. keep me posted
Mar 22, 2010 at 5:48 AM
