2000 Ford Taurus Blower motor
140,000 MILES • 6 CYL • FWD • AUTOMATIC
MARKTALARICO
My air conditioner blower motor sometimes works. Originally it only worked in high speed but not any of the lower speeds. I checked the manual and I changed the blower motor resistor, and it worked fine on all speeds. Today it wouldn't work when I started it first thing in the morning but later when I started it, it worked fine. What gives?
Aug 19, 2009 at 8:24 AM
BMRFIXIT
  • 19,053 POSTS
Work times and times dont
I would suspect a bad blower motor
locate motor and disconnect check for power and check for ground if have both and motor not working than its a bad motor
if missing ground bad resistor no power check relay and ignition switch
always check wiring too
Aug 19, 2009 at 2:48 PM
