2000 Ford Taurus Battery light
18,600 MILES • 6 CYL • FWD • AUTOMATIC
NEWBERRY48
My 2000 Ford Taurus recently wouldn't turn over. I tried to jump start it thinking maybe it was the battery. No luck. I had the alternator replaced, replaced a bad starter. After all this my battery light is still on and it will not hold a charge. I tested the alternator and it is good. Could a bad battery be the cuprit or something else?
Oct 6, 2009 at 11:23 PM
  • 75,988 POSTS
My 2000 Ford Taurus recently wouldn't turn over. Did you meant it cranks and will not start or just won't crank at all/nothing??
Oct 6, 2009 at 11:59 PM
NEWBERRY48
I turn the key and get nothing. I just had the battery tested and it is fine. New alternator, good battery. What to do?
Oct 7, 2009 at 2:23 AM
  • 75,988 POSTS
Other areas could be the starter itself, starter relay, transmission range sensor and ignition switch.
Oct 7, 2009 at 8:07 AM
XCERNFSI
Try replacing the battery cable, that caused a similar problem for me a few years back on my 99 Taurus.
Oct 17, 2009 at 4:21 PM
