2000 Ford Taurus AIR CONDITIONER
189,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSE E DIAZ
THE AIR CINDITIONER DOES NOT BLOW COLD. ABOUT 8 MONTHS AGO THEY PUT I GUESS FREON AND IT LASTED FOR A WHILE WHAT SHOULD I DO
Feb 27, 2010 at 11:06 PM
BMRFIXIT
  • 19,053 POSTS
1st step is to check if system hold freon if not have to check for leaks
if you need to add freon every so often system should be check for leak
A use of dye can be very helpful in finding the leak
Feb 27, 2010 at 11:27 PM
