2000 Ford Taurus ABS - BRAKES
85,000 MILES • 6 CYL • FWD • AUTOMATIC
PRINCEA
I have a 2000 ford Tarus - The ABS seems to kick on at times that I do not think it is necessary. Usually when the roads are wet or there's snow or a pot hole etc at slow speeds when stopping. The car only started doing this a few months ago. I have replaced the rotors, new pads, and also the rear drums. There are no lights on the dash indicating any problem either. I know what ABS is supposed to do, and this car is doing it way to often. Can I unplug a fuse to turn off the ABS without any major problems for testing purposes just to check the rest of the brake systems out?
Feb 11, 2008 at 7:11 AM
B4CAMARO91
My 2000 is dong the very same thing. Did you ever find a fix? any tips would be helpful. Thanks.
Mar 13, 2010 at 12:56 AM
