[quote:2676c6b886="melcturne"]Heater problem
2000 Ford Taurus 6 cyl Two Wheel Drive Automatic 139000 miles
my heater will not get warm heater core is good whats the prblm[/quote:2676c6b886]
Verify that the engine is reaching operating temperature. Temp gauge should indicate near the center of the gauge. Hoses should be warm to the touch.
Verify that coolant is actually flowing through the heater core. Hoses should get very warn at the heater core fittings.
Once you have established that there is actually warm coolant flowing theough the heater core, the next thing would be the blend door motor. This is a small electric motor mounted to the bottom of the heater housing left of center of the car. This is the device that controls whether air comes through the heater core or bypasses it.
Jan 9, 2010 at 3:05 AM
