2000 Ford Taurus
I have a 2000 Ford Taurus the problem i have is when u crank the car the idle was falling below 1 and would shake and sometimes cut off i went and got it checked and the idle part replaced but that didnt fix the problem now when you crank the car it will sit for a min or so then it will start sputtering like it wants to cut off and sometimes it does but after you drive it it seems to be fine but its happening more often when its being cranked, at first it only did it the first crank of the day... so do you have any idea what the problem could be????
Sep 9, 2010 at 7:09 AM
