1999 Ford Taurus where is the temperature control switch lo
FIREWOMAN73
Heater problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
I need to find out where the temperature control switch is located. it is a $20 part but no one can tell me where it is just that it may be the solution to my no heat problem.
Nov 23, 2009 at 12:12 PM
BMRFIXIT
  • 19,053 POSTS
No heat inside the car
and if so the switch is not going to help at all switch is to tell the PCM what is the engine temp
located by the thermostat housing in most cases
if its heat your looking for
this is what you need to do
start and warm the engine
open hood and check by the firewall the heater core hose both should be hot if not
heater core need to be flushed
if both hot blend door in the HVAC box or actuator
let me know what
Nov 23, 2009 at 12:37 PM
