1999 Ford Taurus venting problem
REGINAVAJDAK
Air Conditioning problem
1999 Ford Taurus 6 cyl Front Wheel Drive 160000 miles
I replaced the heater core in my taurus and I tried to remove the center venting when I was trying to figure out where the heter core was. Now the vent is leaking air around the bottom opening and I cannot figure out how to reconnect it properly so that the air will come out of dash vents and not the defroster and floor. Can you please tell me what I did and how I can reconnect the vent system in the middle (behind ashtray and controls) correctly. Thank you for your assitance.
Aug 7, 2008 at 8:51 AM
MERLIN2021
  • 17,250 POSTS
If the air comes out of the defrost and will not switch to vent, you have a missing vacuum hose, look for the black one that comes in from the engine compartment. As for the ducts, I don't know what you took apart, if you can upload a picture?
Aug 7, 2008 at 8:59 AM
