1999 Ford Taurus Trunk Spring Rods
BMCLAREN
I have a 1999 Ford Taurus SE 4 door sedan(mileage=48,000mi) that I need to reinstall the trunk spring rods and need help with how to do it. ie: do you install them with the trunk open, closed, need special tools, etc...?
Thanks in advance,
Bill McLaren
bmclaren_01@hotmail.com
Jul 11, 2006 at 5:17 AM
TAURUSWHEEL
  • 718 POSTS
I think you can do it yourself, removing the actual trunk lid probably is safer with two people however.. be careful they don't get away from you as you're putting them into the notches,,, you'll have to support the trunk lid in the open position,, the notch positions are used to increase or decrease the trunk lid tension when opening, you don't want it flying open..I think the door shoiuld open somewhere between 6-11 inches initially, adjust from there... you don't want it flying up, hitting someone in ther head, not the hot setup.
Jul 11, 2006 at 9:54 AM
Suggested Repair
Support the trunk lid open, preferably with two people. Install the spring rods into the notches carefully so they do not slip, then adjust the notch position so the lid initially opens about 6-11 inches and does not fly open.
Conversation Summary
The owner of a 1999 Ford Taurus SE sedan asked how to reinstall the trunk spring rods, including whether the trunk should be open or closed and whether special tools are needed. The expert said it can be done DIY, that two people are safer if the lid is removed, the lid must be supported open, and the notch positions should be adjusted so the lid opens about 6-11 inches without flying up.
