1999 Ford Taurus temperature gauge
150,000 MILES • 6 CYL • FWD • AUTOMATIC
902RTU
  • 6 POSTS
This summer I did a complete reverse flush to generate some heat from the core and lately I've noticed, as speed and airflow through the radiator increases, the panel temp gauge drops to zero. At idle it returns to normal. Heat is coming from the core - doesn't appear to be a thermostat problem nor is the fan cycling excessively so I'm wondering if a sensor is involved.
Oct 8, 2010 at 4:46 AM
  • 110,251 POSTS
When you say the panel goes to 0, are you refering to the engine temp?
Oct 8, 2010 at 4:15 PM
902RTU
  • 6 POSTS
Yes, the coolant temp gauge, but, after a few minutes of standing still, it returns to normal - a little less than halfway up the gauge.
Oct 9, 2010 at 3:52 AM
  • 110,251 POSTS
It sounds like a bad temp sending unit. Have you checked to make sure the wiring to it is good?
Oct 9, 2010 at 6:13 AM
902RTU
  • 6 POSTS
Should have replaced them both. A few months I did the grey connector so now I'll do the brown. At least I now have a 21mm long socket to do the job.
Oct 9, 2010 at 6:41 AM
  • 110,251 POSTS
Let me know if that fixes it. It could be the sensor itself.
Oct 9, 2010 at 3:30 PM
