Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Interior
Instrument Cluster
Gauges
Engine Temperature
1999 Ford Taurus temp gauge
1999 FORD TAURUS
180,000 MILES • 6 CYL • FWD • AUTOMATIC
KYLEBLUE
MEMBER
temp gauge only shows the temperature when the heat is turned on.
May 29, 2010 at 8:27 AM
BLUELIGHTNIN6
Experienced Mechanic
is this digital or standard gauge cluster?
May 29, 2010 at 9:57 AM
KYLEBLUE
MEMBER
standard gauge. needle only moves when heat is on. turn heat off and needle drops down.
May 29, 2010 at 1:48 PM
BLUELIGHTNIN6
and when the heater is turned on, is the heat blowing hot or just luke warm? is the coolant level in radiator full?
May 29, 2010 at 1:52 PM
KYLEBLUE
MEMBER
blowing hot air and radiator full
May 29, 2010 at 10:50 PM
BLUELIGHTNIN6
ok most likely culprit would be the engine coolant temperature sender, on the rear of engine block near the thermostat
May 30, 2010 at 5:02 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
