HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Starter
1999 Ford Taurus Starter is not engaging.
JAMESCHROUCH
MEMBER
1999 FORD TAURUS
6 CYL
2WD
AUTOMATIC
108,000 MILES
The car will not make a sound.
Tuesday, October 19th, 2010 AT 6:30 PM
SATURNTECH9
MECHANIC
So your car won't turn over at all?Have you had your battery tested and made sure your battery cable's are clean and tight?Also what is the 8th digit of your vin and do you have a multimeter or test light?
SPONSORED LINKS
Tuesday, October 19th, 2010 AT 7:21 PM
Please
login
or
register
to post a reply.
Related Starter Content
1996 Ford Taurus Starter
Electrical Problem 1996 Ford Taurus 6 Cyl Front Wheel Drive Automatic Ok I Had My Starter Checked 2 Times And Both Times They Said It...
Asked by
larry35773
1996
FORD TAURUS
VIDEO
Starter and Set Points Gap!
Instructional repair video
GUIDE
Starter
An engine starter is constructed as a high torque, high amperage 12 volt motor fitted with an electrical solenoid and Bendix gear which is used to rotate an engine between...
1997 Ford Taurus Starter Turns For Split-second Then...
Using A Correct, Tested, New, Fully-charged Autolite Battery, And With One New Ground Cable And New Battery Terminals, And Wires/...
Asked by
GGreub
1997
FORD TAURUS
1995 Ford Taurus Starter
I Need To Know If It Possible That A Starter Cable To Come Of And He Starter Will Be Ok.
Asked by
chrissy_82
1 ANSWER
1995
FORD TAURUS
2003 Ford Taurus Starter
Put A New Starter On And Still Will Not Start. When The Key Is Turned On It Just Clicks.
Asked by
susanquick
1 ANSWER
2003
FORD TAURUS
2001 Ford Taurus Starter
How Do I Get My Starter Off My Car
Asked by
rebadog
1 ANSWER
2001
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Starter Motor Replacement
Starter Replacement
Online car repair manuals
