1999 Ford Taurus stalls
DLLLSMITH
Engine Mechanical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
car starts fine,,idles fine,,when it be driven for 1/2 hr.. all of a sudden it dies and won't start ,,hour or two later,,try to start ..starts right up.. idles fine..it may run a week ,,maybe two ,,,maybe turn right around a hour later and dies again and won't start .. no check engine light ever comes on
Mar 31, 2010 at 12:19 PM
BMRFIXIT
  • 19,053 POSTS
Suspect and check fuel pump and pressure
also after it stalls try to start and press the accelerator paddle
If that gets it going remove and clear or replace IAC valve
Mar 31, 2010 at 11:08 PM
DLLLSMITH
replace the IAC valve..ran it for a while,,shut off then try to restart ,,didn't.. guess i'll have to check the fuel pump pressure
Apr 1, 2010 at 10:01 AM
