1999 Ford Taurus slipping
136,200 MILES • 6 CYL • FWD • AUTOMATIC
TONY KELLEY
I have recently had transmission problems.
I had a mechanic tell me the transmission fliud was 6 quarts low and had a small leak.
He filled the transmission but the next day the tranny was slipping again. I did not loose any fluid I only drove 20 miles.
Another mechanic had tested it and told us the sensor was not working properly.
Could a failed sensor cause the car to slip in and out of gear? Is the sensor a hard part to replace in the 99 Taurus front wheel drive. Is it above / below the transmission?
Oct 4, 2010 at 4:31 AM
  • 110,248 POSTS
Can you tell me what sensor he is refering to?
Oct 4, 2010 at 2:36 PM
