1999 Ford Taurus Shudder
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEAHOLM3
I have a '99 Taurus and it has a pretty bad shudder between 30-50 miles per hour only when it is accelerating. The car slowly starts shaking and then rattles. Its almost as if the car has the shivers. Have a had numerous tests run, found a misfiring cylinder and replaced the plugs, its still doing it. It does seem to be worse going accelerating up hills. Thought maybe a torque converter, but that hasn't been registering on tests either. Transmission hasn't been slipping, so I didn't think it would be that. Seems to be shifting fine. Any ideas would be great.
Apr 15, 2009 at 1:39 AM
BILLYMAC
  • 2,204 POSTS
hi ,go back to the cyl misfire. check the compression on that cylinder. check the injector on that cylinder.
Apr 15, 2009 at 12:04 PM
