1999 Ford Taurus Rough Shifting
NEIL8326
Transmission problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 152k miles
My 99 taurus doesn't shift properly. When getting on the interstate the transmission won't shift until I let off the gas. Also, the rpms surge slightly when slowing down for a stop. The transmission is only about 2 years old. No check engine light on. I scanned it anyway and it came back with no codes. Any ideas would be much appreciated. Thanks
Nov 25, 2009 at 9:46 AM
BMRFIXIT
  • 19,053 POSTS
Check tranny fluids
replace and change filter
if the OD light flashes you should check for tranny codes need a scanner an OBDII reader will not access the tranny code s
Nov 25, 2009 at 12:23 PM
